Sponsored by:
Sponsored by: CARiD
Sun roof
Old Jun 1, 2007 | 12:05 PM
BigBananna3796of4000's Avatar
Default Sun roof
I was curious if eveyone had this problem w/ thier sunroof. When I open my sunroof the black plastic clip pops up anddrags in the wind ,makes a lot of nosie. I retracts back down when i close it.
I cant even use my sunroof with out a annoying nosie.
Does this happen to everyone?
Old Jun 1, 2007 | 04:15 PM
mnboy's Avatar
mnboy
Default RE: Sun roof
Banana,
I have the same black plastic strip (different configurations of holes or notches) on my Chevy SUV and my Pontiac GT. I believe it upsets the flow of air and forces it into the car -- I've put small wood blocks to keep the strip down, and the wind seems to just go over the sunroof hole and not enter the car...
Your right, in the wind noise is much reduced when the strip is held down.
MN
Old Jun 1, 2007 | 04:54 PM
Explain the wood blocks in more detail? I may want to adopt your fix.
Thanks for the reply.
Old Jun 1, 2007 | 05:22 PM
mnboy's Avatar
mnboy
LOL. My simpleton fix, was to use two pieces from a wooden popsicle stick. Using sharp wire cutters, cut the stick into two small length pieces that are long enough to fit into the metal groovesso that they push down the two wires that allow the plastic air dam to raise.Just push theminto placekeeping theair dam down, usually near the end of the slotted gooves, just above the wires. I remove them everytime I close the roof to prevent any damage to the slide mechanism. Itworkedfor me.
MN
PS: I've always liked your posted photo. Pretty cool.
Old Jun 1, 2007 | 05:26 PM
Cool fix I will give it a go around.
thanks for the help
Old Jun 4, 2007 | 03:15 AM
baldyloxs's Avatar
baldyloxs
Like the black plastic!!!! you dont get the vacuum sound with all the windows up and the roof open with it on there.We have problems woth the roof closeing\opening sometimes.Usually after we turn the car off it works fine that way kinda weird ?????
Old Jun 4, 2007 | 02:48 PM
That is wierd. I dont even like sunroofs but it came w/ the car.
