Sponsored by:
Sponsored by: CARiD
bigger rotors only
Old Aug 8, 2007 | 05:14 PM
BigBananna3796of4000's Avatar
Default bigger rotors only
Can you put bigger rotors on the 2006 R/T's with out upgrading the calipers?
Also are the SRT rotors bigger and will they fit on the R/t hub?
Old Aug 8, 2007 | 07:26 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: bigger rotors only
No,you needthe rotors, calipers, spindles and everything else up there because they don't bolt up to the 5.7 stuff. You would bebetter off getting aftermarket stuff.
Old Aug 9, 2007 | 08:20 AM
Will the calipers handle a bigger aftermarket rotor?
Old Aug 9, 2007 | 09:09 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Not sure but to be safe I would keep them paired.
Old Aug 9, 2007 | 05:53 PM
IXLR8's Avatar
IXLR8
I think your asking the wrong question. You should not ask if they fit. Instead try matching new rotors to to the existing calipers. I will bet that someone has some nice slotted or drilled rotors that are "matched" to the calipers. The rotor and caliper are part of a system and should be very carefully upgraded, because your life may depend on it.
Old Aug 10, 2007 | 12:32 PM
Good info and thanks
