Sponsored by:
Sponsored by: CARiD
radio change
Old Oct 7, 2007 | 08:55 PM
imadado's Avatar
imadado
Default radio change
I have just recieved a stockin dash sirius nav radio. I pulled out the my existing stock radio (am/fm
sat.dvd) but the plug doesn't fit and there are not enoughplugs. Is there a adpter kit? How can i convert the wireing? can this even be done? [sm=confused06.gif]
Any help is appreaciated
ima-clueless
thanks
Old Oct 11, 2007 | 09:26 PM
khurst's Avatar
khurst
Default RE: radio change
imadado,
I purchaced a pigtail adapter for mine off of e-bay it allowed me to connect my stockradio to my aftermarket SIRUS and allowed me to adjust the volume to balance everything out. But, If I remember right, it said something about the fact that you could'nt connect it up if you had NAV and stock SIRUS??? Do a search for 06 Charger radio adapter or pigtail on ebay and it should pop up. Let me know if you can't find it and try and check my history for the place where I got it.
BTW where did you get your replacement radio with NAV/DVD and SIRUS.My R/Thas the 6 CD/CASS with DVD in rear (but not stock SIRUS)but the AM/FM reception sucks and the dealer has been unable to correct the problem after over 5 visits. Was thinking of upgrading to the NAV/CD system but want to keep the rear DVD and have some sort of SIRUS option
Hope this helps and let me know how it turns out, Kirk Hurst, Corpus Christi, TX
Old Oct 12, 2007 | 09:21 PM
imadado's Avatar
imadado
I just learned that the nav system I have is a MyGIG (RER) model installed in chrysler products starting last year. Specifically the Seabring. I have contacted a audio specialest and he said that no wire harness or faceplate is available yet. I'm not sure. I have decided not to install the system but sell it and buy a portable nav system. but thanks for your help.
