Sponsored by:
Sponsored by: CARiD
Power Window Motor
Old Oct 26, 2007 | 07:46 PM
BigJim191's Avatar
BigJim191
Default Power Window Motor
Ineed to replace a power window motor on the passengers rear door.Has anyone heard if there was a bad batch of motors installed? A friend of mine has an '06 300C and had his replaced twice on the same door. I'd take it to the dealer but the warrentyhas passed. I checked the master switch and the door switch with a test light for power and both are fine so i picked up a new motor. I've turned a few wrenches beforeand decided to change it myself. Any suggestions on replacing this would be greatly appreciated.
Thanks
Old Oct 29, 2007 | 07:57 PM
733subvet's Avatar
733subvet
Default RE: Power Window Motor
hey jim
just a FYI - had to make an appointment today with the stealership for the same problem except mine was the back driver rear door.
i only have @1300 mi. on mine and it keeps making a "chugging "sound only while going up. there may very well be a bad batch. hope they aint gonna say that it was damaged when i got the windows 20% tinted
Will keep you posted
Old Oct 30, 2007 | 08:09 AM
IXLR8's Avatar
IXLR8
My driver side rear was replaced the first week that I owned my car. Problem? Maybe....
Old Nov 2, 2007 | 11:35 PM
wssb11's Avatar
wssb11
good luck trying to replace it. those door holes are tight and can sometimes be a pain!!!
Old Nov 6, 2007 | 09:53 AM
BigJim191's Avatar
BigJim191
I went to the dealer and bought a new motor/regulator and was only $65.00 and changed it in 20 minutes.
It helps when both units are one assembly, 4 bolts and it's out. Everything is fully exposed after removing the plastic door liner. Not like my wifes Mazda, sliced up my wrists fighting with the regulator and motor inside the door. Thanks for the feedback.
