Mopar coils and sways
Does anyone currently have this set up? Just wondering how good it is?
I was also considering Kw1 and hotchkis.
Also why would I want Adjustable coilovers? Do people really get under the car and change up the settings on a consistant basis? Seems like a waste of money.
I think the Mopar coilovers are made by KW and it’s the variant 1. Hotchkis yes got them installed and you will love them.
The Mopars and KW variant 1 have height adjustment. KW variant 2 has damper adjustment as well.
You might get an 1" drop and wanted an extra .5", or you may have got a 1.5" drop and want to raise it .25" for ground clearance. The adjustible height gives you the ability to set the height instead of being stuck with what the vendor product does by default.
I would think once you get the ride height adjusted you wouldn't play with it much. If you have the variant 2 you can fiddle w/the damper adjustment but unless your racing on road courses your probably not going to fiddle with them once their dialed in.
Ahhh I didnt know it was the dampening that is adjustable on Kw2's.
Waht about Mopar sways? I dont ever remember seeing any posts on them if they are good or not?
