Sponsored by:
Sponsored by: CARiD
2 Mod Issues
Old Feb 12, 2008 | 05:10 PM
733subvet's Avatar
733subvet
Default 2 Mod Issues
have 2 questions for anyone that can help me out
1 - just had my gauge pod installed today but one of them is a oil pressure gauge and they cant figure out where to intall it on the 5.7 - wiring is run but they dont know how to hook it up or to what
2 - had altezza tailights put on the rear and there is about an 1/8 gap between the lights and body - LOVE how they look but worried about snow,rain getting in there and shorting something out - anyone else have this issue and how did you fix it (if you did)
can ANYONE help with these 2 issues
thanks in advance
Old Feb 12, 2008 | 05:43 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: 2 Mod Issues
No idea on #2
On #1... The OEM sensor is located by the oil filter. Not sure if you want to tap those sensor wires because it's .5 volt and you guage is probably setup for 12 v. Did the guage come w/a sensor and are you wondering where to put that?
Old Feb 12, 2008 | 05:50 PM
733subvet's Avatar
733subvet
have to admit i am not 100% sure - have to check the box
its an autometer gauge so i am thinking it came with a sensor ?
Old Feb 12, 2008 | 06:06 PM
733subvet's Avatar
733subvet
ok checked the box since they were nice enough to give it back to me
it has a round metal piece(sorry) that is threaded on both ends one opening is roughly 1/2" od and the other end is offset to the edge and roughly only maybe 1/8"
sorry i dont have a digital camera or i would send a pic
Old Feb 12, 2008 | 06:56 PM
733subvet's Avatar
733subvet
ok sorry to keep bothering you
looked at the generic direction sheet they give you in the box - it is a pressure sender !
but still cant find out online as to where/how it gets installed - is this something you would recommend taking to the dealer to finish since they HOPEFULLY know where to install it ?
again - want to thank you for your help
Old Feb 12, 2008 | 09:41 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
If you take the plastic skid belly pan off and look up at the oil filter (as if you were changing out the filter) Above the oil filter you will see theOEM oil pressure sender. Above that senderthere isa plug with a hex head, remove that and the autometer sensorwill screw into it. Runthe wire & your done.
Good luck on that project.
Old Feb 13, 2008 | 11:28 AM
733subvet's Avatar
733subvet
Mango
once again you saved my @ss ! THANK YOU
now if i can just figure out the taillight issue [X(]
was thinking about cutting off the washers on the 3 double ended studs that go through to the trunk if that would fix it ? i think they may be the culprit
any reason NOT to try that ?
