Sponsored by:
Sponsored by: CARiD
R/T Charger ignition coils and cam covers
Old Feb 18, 2008 | 05:26 PM
SouthernComfortHemi's Avatar
SouthernComfortHemi
Default R/T Charger ignition coils and cam covers
Can anybody help with this one.
Are the cam covers and coil packs on a R/T or Daytona the same as on a 300C or Charger.
I need to know as I plan to use composite R/T manifoild on my 5.7 hemi truck with heads and cams.
Thanks fot your help
Old Feb 18, 2008 | 08:07 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: R/T Charger ignition coils and cam covers
First welcome to the forum SouthernComfortHemi.
Being their both 5.7s and 06 or newerthe coil packs are interchangable. I'm not sure what a cam cover is, are you talking about the timing chain cover?
Old Feb 18, 2008 | 08:17 PM
SouthernComfortHemi
Thanks for reply.
In more detail.
I wanted to go the SRT8 intake route but is was just to expensive and did not work very well on 5.7.
However I read a tset on using th R/T composite banana mnifold and this gave very good results.
Its an easy fit on the 5.7 2006 truck block..the throttle body is the same
the rails look as if they mount in a different manner but i can sort that...the injectors are the same.
The cost would be in new rocker covers with new coils...that was my worry.
Also the clearence on the timing cover and A/C unit pipes.
Thansk for your input it is making things clearer.
Best Regards...bryan
Old Feb 20, 2008 | 09:23 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
The 5.7 rocker covers are also the same across the LX platform (Charger/Magie/300c).
