Sponsored by:
Sponsored by: CARiD
Sway bar install: this cant be right??
Old Feb 28, 2008 | 12:42 PM
BigBananna3796of4000's Avatar
Default Sway bar install: this cant be right??
I was just quoted
$170 for the front and
$510 for the back.
6 hours alone for the rear sway bar installation. The guy says he has to lower the sub frame to so it.
Old Feb 28, 2008 | 12:49 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Sway bar install: this cant be right??
I can't vouch for their per hour cost but...
The fornt sway will take about half an hour <= if you take your time.
They are correct on the rear, there are 4 bolts you remove to drop the "rear assembly". You drop it about 4-5 inches, just enough to pull the sway out and thread the new one in but don't drop it enough so the break lines are tight. * * * EDIT * * * I forgot to mention... It took me about an hour to install the rear sway in my house garage.
It's a good idea to get aligned once that is done.
