Drivers Side Headlight
I have 07 Charger with Road & Track (Think the Daytonas are the same with this) I went to change out my headlights and can access and change the passenger side Low Beam but realized shortly after that I cannot access the drivers side Low Beam. Seems there is a Power Steering reservior there and a 'big plastic thing' which looks like an intake of the front of the engine (is that a cold air intake?)... As you can see I am not much of a mechanic... Can I do this without taking my car into the dealer?? And what is the 'big plastic thing'.
Thanks Boyz.
Thanks Boyz.
Your correct that's the intake. It will take about 5 minutes to take it off, there's one bolt (use a 10mm socket) in plain view and then a clamp (use a flat scredriver). You shouldn't have to remove the intake tube from the throttle body or the air sensor wire.
Hope that helps.
Hope that helps.
Your going to gain a few HP but not that much over the OEM setup. Once your pushing more HP like after installing headers/cam or boosting then your going to see more gaines.
I started with a drop-in OEM filter replacement from K&N (a rechargable one that can be cleaned and re-used) then built my own Cold Air Intake that cost around 120-130ish.
