Sponsored by:
Sponsored by: CARiD
My dash board says
Old May 6, 2008 | 12:40 PM
BigBananna3796of4000's Avatar
Default My dash board says
On the right it has the ESP off(car w/ squiggly lines) and below that is says BAS. ON the left is says ABS.
I got sidways making a turn and then the dash board lit up like a Christmas tree.
Did I totally disable the ESP?
Old May 6, 2008 | 01:11 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: My dash board says
Since you didn't mention it I assume you didn't disable ESP on purpose.
That could be a Tire Pressure Sensor (TPS) issue.
Old May 8, 2008 | 07:03 AM
73dart's Avatar
73dart
In my prevoius chrysler vehicles any time there is wheel slip detected the esp/bas light would flash letting you know that the system is working. I assume that the charger would be the same but I can check the manual when I get home.
Old May 8, 2008 | 07:37 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
That's correct 73dart.
Was it justthe lights flashing BB3796? If so then your torque management was on and it wasn'tdisabled.
If those lights are on solid it's probably a TPS issue.
Old May 12, 2008 | 08:17 AM
I filled all tires with air and still the lights are solid on.
What is TPS? Also My super chips is set to reduced torque managment.
Old May 12, 2008 | 09:39 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
TPS - Tire Pressure Sensor
Yes SuperChips has a setting to reduct torwue management but it doesn't disable it, I don't believeSuperChips is the issue here.
Old May 12, 2008 | 09:45 AM
But the TPS is not lit up? It was and I corrected that but it did not correct the traction control and ABS. My ABS is not working I tried it yesterday. The car skid a good 10 feet before stopping. Just locked them up.
Old May 12, 2008 | 10:54 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
If your esp, bas & abs lights are on then check cruise control, I bet it doesn't work. If that is the case there is a TPS in one of you wheels that isn't working properly.
Old May 12, 2008 | 11:21 AM
Is that under warranty? Also how would i know which one is bad?
Old May 12, 2008 | 01:33 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I would assume it's covered.
Unfortunately the PCM doesn’t itemize the TPSs so as far as I know it's trial and error to find out which one is bad. Maybe a tech at the dealership can tell if they hook up a starscan.
Look at it this way... you have a 25% chance of getting it the first try, from there the odds get better with each guess [&:]
