Sponsored by:
Sponsored by: CARiD
Charger Intake System
Old Oct 29, 2008 | 04:17 PM
True Flow's Avatar
True Flow
Default Charger Intake System
True Flow XDI Air Intake System
True Flow Releases the new XDI Air Intake for
the 2005-2009 Chrysler 300 and Dodge Charger & Magnum Hemi.
Phoenix, Arizona – September 2008 – True Flow, a leading manufacturer of automotive air filters and air intakes is pleased to introduce the True Flow XDI Air Intake system for the 2005-09 Chrysler 300 and Dodge Charger Hemi. True Flow has taken a unique approach to develop an intake system with ultra high flow, aggressive sound and extreme looks.
The Chrysler 300 and Dodge Charger suffer from undersized air filter boxes and restrictive air filters that choke down air flow to minimal engine requirements. True Flow’s design team looked to improve on the intake system to achieve maximum performance from the cars.
True Flow removes the air box and tubing that connects to the throttle body and replaces them with a smooth tube, silicone couplers and a high flow aluminum canister with a massive 5 inch inlet and outlet. Finally, after extensive research on a flow bench, they changed the direction of the air filter so that the air flows from inside-out of the filter. True Flow calls it “inverted air flow technology.” This revolutionary change increases the air flow by over 50 percent and increases power by up to 27 horsepower and up to 62 foot pounds of torque.
A critical part of the XDI intake system is its True Flow Air Filter. Unique to the industry, foam air filters have awesome performance capabilities and filtration properties, filtering even the smallest debris. These incredibly durable air filters are easily cleaned and offer a limited lifetime warranty with excellent performance.
