Sponsored by:
Sponsored by: CARiD
6.1L HEMI V-8 Stats: Charger SRT-8:
Old Mar 11, 2005 | 09:38 PM
redriderbob's Avatar
redriderbob
Default 6.1L HEMI V-8 Stats: Charger SRT-8:
Description: Eight cylinders, 90-degree V-type, liquid cooled. Deep-skirt cast iron block with cross-bolted main bearing caps, aluminum alloy heads with Hemispherical combustion chambers
Bore x stroke: 4.06 x 3.58 (103 x 90.9)
Camshaft: Silent chain, 5-bearings. Bi-metal material except number 3 Babbit. Deep-fillet rolled journals for improved fatigue life, press fit damper to minimize torsional vibration
Compression Ratio: 10.3:1
Crankshaft: Nodular cast iron, tuned assembly vibration damper, 6 bi-metal bearings
Displacement: 370 CID (6,059 cu. cm)
Engine speed, max: 6,400 rpm (electronically limited)
Fuel injection: Sequential, multi-port, electronic, returnless
Fuel requirement: Premium 91 octane (R+M)/2 - recommended
Knock sensors: Dual, wide band
Oil capacity: 7 qt. (6.6L)
Power: (SAE net) 425 bhp @ 6200 rpm
Torque: (SAE Net) 420 lb.-ft @ 4800 rpm
Valve system: Pushrod-operated overhead valves, 16 valves, 8 conventional hydraulic lifters with roller followers
DaimlerChrysler Media
On Another Note: I posted last week that production of the 2006 Dodge Charger SRT-8 (LXDX48), will start production on 9/12/05!
redriderbob
Old Mar 23, 2008 | 12:46 PM
twinturbo's Avatar
twinturbo
Default RE: 6.1L HEMI V-8 Stats: Charger SRT-8:
friend of mine bought last one off the line block is actually painted orange has a plaque on dash saying who it was built for
