Sponsored by:
Sponsored by: CARiD
2006 lighting problem
Old Dec 15, 2009 | 07:31 PM
txcharger's Avatar
txcharger
Exclamation 2006 lighting problem
just bought a used 2006 to give the wife.... the rear running lights keep blowing the fuse. I replace the fuse and it will work for a bit and then blow.
I see on the internet a lot of chatter about the rear lights but no direct cause identified. Does anyone have any ideas? is the a common problem with the 2006? All the wiring looks good and the brake lights will always work even when the running light fuse is blown.
I need help before I end up in the doghouse forever!!!!!!!!
Old Dec 15, 2009 | 08:25 PM
txcharger's Avatar
txcharger
Found the problem, the wiring harness had dropped down and was touching the muffler causing a short. I fixed the problem and the tail lights again work.
Thats a bad route for the harness to travel. Directly over the muffler pipe...
Old Dec 15, 2009 | 08:42 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the forum TXCharger.
I saw a thread on another forum with the exact same resolution...
"Went to the dealer. According to the mechanic the wiring harness had dropped down and was touching the muffler causing a short. He fixed the problem and the tail lights again work. "
Glad it's resolved!
