Sponsored by:
Sponsored by: CARiD
Transmission Slipping
Old Jan 5, 2010 | 10:53 AM
starbase129's Avatar
starbase129
Question Transmission Slipping
I have noticed some slippage in the transmission on my 2008 Dodge Charger.
On about four occasions over the last two months, I will come to a stop. When I give the car some gas to go, the car initially doesn't move. After 2-3 seconds, it seems to lurch into drive. It's almost like the car slips into neutral as I come to a stop.
Any ideas what is causing this?
Old Jan 5, 2010 | 11:05 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the forum starbase129! What kind of Charger do you have?
Old Jan 6, 2010 | 05:18 PM
starbase129
Thanks. I have the base sedan model, 2.7L V-6.
Old Jan 7, 2010 | 07:33 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
With the information given all I can think of off hand is to check the transmission fluid level. Since it's an 08 is it still under warranty? If so let a dealership service department take a look at it.
Old Feb 16, 2010 | 05:23 PM
starbase129
Thanks. I had it checked out at a dealership, and the transmission was 2 quarts low. Apparently, the mechanic who changed the fluid and filter last time did not put in enough fluid (the mechanic at the dealership said nothing was leaking underneath).
