Sponsored by:
Sponsored by: CARiD
Mold smell in 2007 Dodge Charger
Old Apr 21, 2010 | 12:32 PM
sda1957's Avatar
sda1957
Default Mold smell in 2007 Dodge Charger
I have a 2007 Dodge Charger that has a mold smell when I use the heater or the a/c. We’ve tried spraying Lysol into the air intake and have also taken it to a dealer who also used something that was sprayed into the air intake but nothing has helped. I’m fairly certain the condenser hose is clogged because I haven’t seen any water leaking after the a/c is run. Dealership says they would need to remove the dashboard in order to get to the condenser hose to check it. Is there another way to get to the hose or any other ideas that we could try would be great. Thanks
Old Apr 22, 2010 | 08:52 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Sorry sda, I haven't seen this problem on any vehicle, but a clogged hose sounds like a good place to look. I know you were looking for answer about anything other than removal of the dash, but on these cars, everything is pretty much located behind the dash. The good news is that for a dealer, removal of the dash is a quick job, so don't worry about anything getting damaged or thinking that the job is something to extreme.
You do need to get that fixed though and quickly. If it is actually mold, everytime you and your passengers are breathing that in, it is making you sicker and sicker.
Old Apr 22, 2010 | 10:08 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Wow that's not cool. Did you already replace the cabin filter?
Old Apr 25, 2010 | 04:07 PM
brettj2408's Avatar
brettj2408
i assume your dealer is smarter than stupid telling you they have to remove the dash to find a foul smell instead of checking the cabin air/HEPA filter first.
