Sponsored by:
Sponsored by: CARiD
Need help with brake bleeding
Old Apr 26, 2011 | 09:43 AM
Mrwray's Avatar
Mrwray
Question Need help with brake bleeding
I had to take off my front driver caliper off while working on my 06 charger R/T. When bleeding it back I had my wife hold the pressure on the brake pedal while I loosened the bleeding nipple screw on the top of the caliper to release the air. I repeated this process 4 different times. Brakes work fine,"can still feel a lil air when braking" and now the ABS,ESP/BAS, and ESP icon,"the car slipping icon" lights r on and won't go off. They will go off for a few seconds but come right back on. Wat do I need to do?
Old Apr 26, 2011 | 09:22 PM
POWER SEDAN's Avatar
POWER SEDAN
Check behind the both front wheels and make sure you didn't accidently disconnect or loosen the clip for ESP wire.
Old Apr 26, 2011 | 10:33 PM
Mrwray's Avatar
Mrwray
I will b sure to check tht, I cant seem to get 100% of the air out of the line. Could this b triggering the trouble lights? If so wat am I doing wrong. My wife holds the pedal to the floor as I loosen the bleeding nipple? She doesn't let off until I tighten the nipple back and tell her to let off. I've repeated the process a few times but still has tht feeling in the pedal like air is still there
