Sponsored by:
Sponsored by: CARiD
transmission oil
Old May 11, 2011 | 06:45 PM
4stevd4's Avatar
4stevd4
Default transmission oil
after how miles should you change you transmission oil for a 2007 charger
Old May 15, 2011 | 05:17 PM
DanPop's Avatar
DanPop
I did mine at 30K and will keep up that schedule. And don't just do a change, do a flush.
Old Jun 3, 2011 | 12:35 PM
RTENUTO's Avatar
RTENUTO
How much did you pay for a flush?
Old Jun 4, 2011 | 02:12 PM
DanPop's Avatar
DanPop
I honestly don't remember, I had other work mixed in.
Old Jun 8, 2011 | 04:38 PM
steak59's Avatar
steak59
probably like $160 ish, if you do it at the dealership. I think quick lube place charge around $100, But I recommend go to a real shop for any car work.
Book said every 60k for trans, 48k for rear differential.
But most ppl recommend 30K for trans and 45k for rear Dif. it makes a difference in the long run. The older Nag1 trans had some problem with Water getting into Trans fluid over time. better to do fluid flush more often
Old Aug 26, 2011 | 04:06 PM
ChargenU's Avatar
ChargenU
is it possible to do my own tranny flush or no ?
