Sponsored by:
Sponsored by: CARiD
2010 AWD R/T Charger
Old Jun 15, 2011 | 10:14 PM
mammoo's Avatar
mammoo
Default 2010 AWD R/T Charger
I need help!!!! My 2010 AWD R/T Charger has a front end vibration. I have had the rotors replaced, was told they were warped. Tires balanced 2x and rotated too. Still have the vibration. So they put new tires on. VIBRATION still. UGH. Rebalanced new tires again. It vibrates at 45 MPH and again between 62-68 MPH. They have no idea what is wrong. Anyone having the same problem, or is it just me.
Mary
Old Jun 16, 2011 | 10:55 PM
steak59's Avatar
steak59
Front end vibration as in Steering wheel shake? ur car still under waranty?
possibly drive shaft. ask dealer to remove Front drive shaft and put the car on 2wd Test mode and drive the car.
there is a very slight possibility it could be the strut too.
also, keep speed steady, but try to force the trans into another gear with shifter selection if possible.
Old Jun 17, 2011 | 09:12 PM
mammoo's Avatar
mammoo
Smile
thanks for the reply, yes it's mostly in the steering wheel. yes still under warranty. i'll make the suggestion about the front drive shaft.
mary
