p0301 code
Hi guys; Engine amber light came on and after using key off/on/off/on p0301 code showed on panel; I think it's (P0301 to P0312 — Cylinder misfire detected where the last two digits are the cylinder number, e.g. P0303 = cylinder #3
by WALABY
Cycled # 11 fuse @ fuse box (PCU). Engine light went off but p0301 is still there and got some p2 coded on cluster. Any idea what should I do next.
Thanks
JT
by WALABY
Thanks
JT
you pull the spark plug out and see how they look. If you are lucky, maybe all u need is a tune up.
swap the coil pack of cyln #3 to another cylinder, see if code moves with it.
And then you try run compression test, and swap injector.
I believe cylinder 3 is on the driver side 2nd cyln from the front.
