Sponsored by:
Sponsored by: CARiD
Charger RT 2007
Old Jan 29, 2013 | 04:37 PM
erincastillo's Avatar
erincastillo
Default Charger RT 2007
I have 2007 dodge charger rt idles low, trebbling noise bottom of my exhaust i feel the car moves , rpms drop and it feels like it wants to shut off. It stall on me at a stop sign and ones driving into my driveway . I have change the pcv valve and throttle body . It only does this at low speed of 5mph or at a complete stop on Drive or PARK. I recently took it to a mechanic shop who tell me only thing they can think of is flashing the system . NO CODE.
Old Feb 1, 2013 | 04:33 PM
DodgeCACares's Avatar
DodgeCACares
Erin,
Are you able to easily duplicate your concern? Did you end up having the flash completed? If you'd like to PM me your VIN#, I can review to see if there are any recalls or bulletins pertaining to your vehicle.
I look forward to hearing from you.
Old Feb 2, 2013 | 02:53 PM
erincastillo
No I did not have my system flash. My vin number
2B3KA53H17H782207 . Stop at a red light my car's rpm jump up and the car just shook but it did not die. At another stop the car did the same again.
Old Feb 3, 2013 | 12:26 AM
erincastillo
Default I need help
I keep hearing a noise coming from the right rear like water dripping or clicking after the car has been turn off .
Old Feb 5, 2013 | 02:30 PM
DodgeCACares
Erin,
I have sent you a Private Message if you are seeking additional assistance reviewing your concerns.
Let me know if you have any questions or concerns.
Old Feb 6, 2013 | 12:49 AM
steak59's Avatar
steak59
That's normal, it is your exhaust, any car would do that.
Also, Check your Trans fluid Level and condition I've actually seen low Trans Fluid cause die out on stop light. I do NOT know how or why, but seen it a few time.
Old Feb 7, 2013 | 07:17 PM
erincastillo
The car currently at the dealer can't find anything wrong with the car or code . They have check the transmission Fluor everything looks good. They did mentioned I should not be using synthetic royal purple oil but the Mopar because they did get a code the wrong oil was being put in.
Only thing they will due is update the system "flash" iAm hoping this will solve my problem.
