Sponsored by:
Sponsored by: CARiD
Front End Rattle Over Small Bumps
Old Mar 26, 2013 | 07:54 PM
LadyHemi's Avatar
LadyHemi
Default Front End Rattle Over Small Bumps
Hello All! I need your help. I have a 06 Charger RT that I baby! She started making noises on the front right side, so I changed the strut/strut mount, Tension Strut, and Sway Bar End Links. I already had the tie rods replaced prior to that, my mechanic says bushings and ball joints look good, and also my rack and pinion is tight, but we can not locate that awful rattle noise. It is only on uneven small surfaces that you hear it. It is common in RT and SRT, just wondering has anyone been able to solve this mystery. What am I missing?
Thanks
LadyHemi
Old Aug 4, 2013 | 11:32 PM
mopowa's Avatar
mopowa
Had the same problem. my noise stopped with slight pressure on brake. Changed anti rattle clips on brakes and caliper pin seals and used brake squeel quiet (thick red orange liquid that has a elmers glue bottle applicator) applied to back of brakes where pistons and caliper hits pads and the noise is finally gone. after putting up with this noise for going on two years. Had stabilizer end links,torsion struts and stabilizer bushings changed by dealer and they couldn'i fix it. after 1000's of dollars at dealership, fixed it myself for under fifteen dollars. GOOD LUCK
