Sponsored by:
Sponsored by: CARiD
front end rattle 07 3.5 charger
Old Jul 3, 2013 | 04:36 PM
acoose's Avatar
acoose
Default front end rattle 07 3.5 charger
I have a 07 charger with a rattle when going over bumps just took It to a dodge dealership and they changed the tie rod end but still the noise is there I don't want to spent thousands trying to chase this problem does anyone have any solutions to this problem any help would be appreciated thanks
Old Jul 8, 2013 | 04:31 PM
scatpackmopar's Avatar
scatpackmopar
If you are able to do the work yourself here is the most common problems associated with the front end clunk. Lower forward control arms (my 06 Chargers were worn out) easy swap, lower aft control arms which have the ball joints and shock attachments on them, and the sway bar linkages, and the shock mount bushings. I have also read that the brake pads can make the clunk if they have any play in them. All in all I spent under $400 doing my front end myself in a buddies garage. I ultimatley solved the problem from returning by buying a 2012 Charger
