Sponsored by:
Sponsored by: CARiD
Explanation please??!!!
Old Jul 6, 2013 | 11:43 PM
LakishaClark's Avatar
LakishaClark
Default Explanation please??!!!
Hi! I have an 06 dodge charger. Can anyone offer an explanation as to why my key wont turn when inserted to lock or unlock the car door? If anything I would think that the remote will give me trouble but no. I have a spare key that does open when I insert it to unlock it. That's weird.
Old Jul 7, 2013 | 06:50 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
If it is a key that you use regularly and have on your key chain, it is not unheard of that the key can get bent or a tooth chipped from everyday use causing it to work. It may look right to you, but the slightest imperfection in the key will render it useless.
Old Jul 8, 2013 | 12:36 PM
LakishaClark
Thanks but the same key opens the trunk when i insert it. I may just be purchasing another key.
Old Jul 8, 2013 | 12:41 PM
aromanj92's Avatar
aromanj92
could be just a bad chip in that key with sensor for the door. dealer will replace it for prob 75-150 bucks depending where your at
Old Jul 8, 2013 | 04:27 PM
scatpackmopar's Avatar
scatpackmopar
I agree with the bad chip. The sensor isnt recognizing the key so it isnt letting you unlock it with the key. Dealership should be able to fix that pretty quickly
Old Jul 9, 2013 | 01:52 PM
LakishaClark
Thanks for the responses. I tried it yesterday and it worked. I believe it was stuck. -whew-
