Sponsored by:
Sponsored by: CARiD
Need some help here
Old Feb 26, 2014 | 09:58 AM
Brian_Taylor69's Avatar
Brian_Taylor69
Default Need some help here
I just bought a 2007 Charger , 2.7 yea I have heard mistake on the 2.7 but, my problem is, it was running perfect and last few days when it sits over night and i start it the next day i get mad lifter ticking,that does NOT go right away, I have the correct oil, and a new filter,does this engine have a oil pump or sending unit in it? i have been around cars my entire life and I have seen startup lifter ticking ,but this isnt it, i drove it today 10 miles before it went away and that was after i turned it off and restarted it its went silent and running perfect again, can any one help with info on this?
Old Feb 26, 2014 | 10:54 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It might not be a lifter. It could possibly be the primary tensioner not building up oil pressure, in which case a catastrophic timing chain failure might be in your future.
Old Feb 26, 2014 | 11:59 AM
Brian_Taylor69
Default 2.7 lack of oil @ lifters
I appreciate the help ,I will immediatly inspect the primary tensioner pulley,and advise..
Old Feb 26, 2014 | 01:03 PM
TNtech's Avatar
TNtech
I meant timing chain primary. It's internal. Don't mess with it if you've never done one. Of course I would have to hear it.
Old Feb 27, 2014 | 08:37 AM
Brian_Taylor69
Default Does a 2007 Charger 2.7 have a oil pressure switch or sending unit ?
2007 Charger 2.7
Thanks for the help (Question) there is obvesiously not enough oil going to the top of the motor , ,is there a oil pressure switch or sending unit that could cause this ??
Old Feb 27, 2014 | 09:54 AM
TNtech's Avatar
TNtech
2007 Charger 2.7
Yes, the switch is on the side of the engine. It won't do anything to the actual pressure though. You probably have a light for it, so you'll need a gauge to see what it is.
Old Mar 1, 2014 | 12:06 PM
Brian_Taylor69
Default 2006 Charger ticking at startup and didnt go away
well im glad to say I found the problem , under the valve cover there was a roller rocker in the back that was loose from a valve lifter not expanding and doing its job , needless to say it made the engine loud and run like crap from not operating the valve, I took it out and replaced
(just the bad one) and its running great..
