Sponsored by:
Sponsored by: CARiD
2011 Charger RT gear shift light bulb?
Old Oct 10, 2014 | 02:25 PM
pete315's Avatar
pete315
Default 2011 Charger RT gear shift light bulb?
Question- got a 2011 Charger with center console shift. Does the PRND light up to indicate which gear you are in? When I turn on the lights, I do get the blue light which illuminates the entire strip but if you're in drive, the "D"does not light up. My wife drives this car and she thought the letters light up whichever gear you're in. I took shift cover plate off and only see one wire harness/ bulb for when headlights are turned on but I see no wire or bulb for the PRND.
Old Oct 15, 2014 | 08:53 AM
DodgeCACares's Avatar
DodgeCACares
pete315,
The shift lever indicator is within the instrument cluster, between the speedometer and tachometer. The selected gear will be illuminated.
