Sponsored by:
Sponsored by: CARiD
06 Charger 3.5, Throttle Body
Old May 4, 2015 | 11:44 AM
ellislamb's Avatar
ellislamb
Default 06 Charger 3.5, Throttle Body
When I replace my throttle body does the car need to re-learn ????
If so how do I do this.
Car high revs to 2500-3000 rpm. Stays there for short period of time. Then comes down, sometimes it shuts all the way down after that. I have to re-fire it. This is new and it has never done this before. 200,000 miles. No problems until now. Still on the original timing belt, needs to be replaced I know.
Has anyone else experienced this before ? Thanks for the help.
Old May 14, 2015 | 09:15 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You seem to have a vacuum leak. Check the EGR tube seal going into the rear of the upper intake.
Old May 14, 2015 | 10:53 AM
Did you disconnect the battery after replacing the TB? Is this an aftermarket or OEM TB?
