Sponsored by:
Sponsored by: CARiD
ac problems
Old Mar 27, 2017 | 02:57 PM
luke guillory's Avatar
luke guillory
Default 2006 Charger AC Issues
compressor turns but do not get cold air. seems to be only couple things not to work. could be the cold and hot air difusser ore maybe low pressure switch which i think is the transducer swiitch but it still turns the fan on. could it be the switch partly works or no.2006 dodge charger
Try to figures why the ac isn't cooling not low think it could be transducer or the hot cold mix valve not sure. Can't getinfo from manual compressor engauges and turns will Not give cool air. Anybody could you please give me more info .thanks
Old Apr 25, 2017 | 02:49 PM
Lasharna Moody's Avatar
Lasharna Moody
Default 2013 dodge charger a.c. problems
I have been to the dealership several times in the 2 months i have owned this car with the same issue they sit in the car and feel that the ac is not blowing cold at all it's not even allowing the circular to be turned on it blinks and then turns off each time they feel its warm they turn it off hook it up to a machine that resets and runs tests and then it starts working again. I'm told everytime it happens bring it back I do and leave with the same exact answer nothing. A few days later same thing happens.
