2014 Charger RT error codes
This may have been asked but I am new to this forum. I traded in my 06 300C on Saturday and bought a 14 Charger RT. Now that I have a push button start in lieu of a key, I now do not know how to check the error codes like I could with a real key. Is there a way to check the codes without a scanner?
any vehicle 1996 (obd II) and newer require a scan tool to check codes....this includes your 06 300C.
If you are referring to a bulb check of the cluster with the "key" on engine off....press the start button 2x with the brake pedal not pressed.
