Rim Sizes??
Hi All, I am thinking about getting an 11-14 Charger R/T AWD. I have some snow tires that are 17s. I looked on various sites and found that the common rim size is 19" on these...Just wondering if a 17" rim will physically fit over the caliper and rotors and such.
What do you mean by that exactly? If I understand, you are saying that rims are not interchangeable from AWD to RWD...but if I find a 17" Rim with the bolt pattern and back spacing for an AWD, then I should likely be fine??
Same bolt pattern but offset is different. Just need to verify that the 17's will clear your brakes.
