Sponsored by:
Sponsored by: CARiD
2006 Dodge Charger 3.5l need some information
Old Feb 16, 2018 | 10:07 PM
Ronan420's Avatar
Ronan420
Default 2006 Dodge Charger 3.5l need some information
okay like I said in topic I have a 2006 Dodge Charger sxt with a 3.5l engine. I took the radiator and ac condenser off to remove the ac clutch pulley to put s new bearing in everything is back together fine so finally to the question what is the r-134a capacity? The owners manual does not say and the sticker isn’t readable. Another question is since I disconnected everything to take it out should I vacuum the ac system before I recharge the ac, I know there isn’t any leaks just took off to get to the clutch pulley easier.
Old Feb 16, 2018 | 10:36 PM
Yes you will need to put it under vacuum. Since you opened it you should replace the drier as well. Don’t forget compressor oil. Can’t help with capacity. Hopefully someone will chime in.
Old Feb 16, 2018 | 11:08 PM
Ronan420's Avatar
Ronan420
So putting it under a vacuum will also take the compressor oil out? Sorry I don’t know much but trying to learn so I don’t have to pay more for a mechanic to do it.
Old Feb 16, 2018 | 11:17 PM
AC systems are not something you want to fool around with if you don’t know what you are doing. Extremely high pressures are present in the system while in operation.
Old Feb 16, 2018 | 11:24 PM
Ronan420's Avatar
Ronan420
i understand and it’s under extremely high pressure I am sure the air lines and compressor at my job are higher pressure will be very cautious just rather learn how to fix my own car 🙃
Old Feb 16, 2018 | 11:54 PM
primem's Avatar
primem
no, a vacuum will not pull oil out of the compressor sump. a small amount of oil comes out with the refrigerant during recovery. that amount should be added after the system is vacuumed. a vacuum for 20minutes minimum is needed to boil out all of the moisture you have let in by opening the system. technically, you should replace the reciever drier as the dessicant is now saturated from air exposure. any moisture trapped in the system creates acid when it contacts the refrigerant, it also lowers the systems efficiency.
the only accurate charging method is with a a/c machine. home charging is not accurate. get a quote, its not that bad.
If you must, the system capacity is 1.625 lbs
