Air Flow through passenger vents only
I have a 2006 Charger with the Hemi 5.7
The vents on the passenger side only blow hot air no matter what the setting on the dash.
Dual control, air conditioner works on the drivers side, moves from floor to defrost on drivers side.
There is a white arm that is attached to an acuator on the passenger side, on the transmission side of the car. The arm moves when you change from defrost to vent to floor but the arm is not attached to anything. Is there a gear that should be there?
