Sponsored by:
Sponsored by: CARiD
trans problem 2007 dodge charger 5.7 stuck in drive
Old Aug 17, 2018 | 04:35 PM
Finesse202's Avatar
Finesse202
Default trans problem 2007 dodge charger 5.7 stuck in drive
Hey guys, i got to work this morning in the parking garage and shifted my car into reverse to pull into a parking spot, in reverse however, the car proceeded to move as if i had it in drive on acceleration. I shifted back to drive, then to reverse again, same thing. I then shifted the car into park, but it stayed in drive. I turned the car off and attempted to start it up again and it wouldnt start up. It seems as if the transmission is stuck in drive and will not shift when the shifter moves. The only way i get the car to start is by unplugging the connection under the dash which is attached to the transmission control module.. However, when i plug it back in? I still can't shift gears. The dash display shifts through as i move my shifter, but again, no response from the transmission
