Sponsored by:
Sponsored by: CARiD
P0305 code after spark plug, injector and ignition coil replacement
Old Mar 9, 2019 | 07:37 PM
Louis Ochs's Avatar
Louis Ochs
Default P0305 code after spark plug, injector and ignition coil replacement
my 2010 Dodge Charger rt keeps throwing me the code p0305 which is a misfire on cylinder 5(it’s a v8 5.7) . It tells me it’s a faulty ignition coil or spark plugs . I’ve replaced both , which led me to believe it’s the fuel injector . I have now replaced that too , the symptoms are idolizing very rough , the check engine light blinks and I keep loosing acceleration until I gas it . I’m pretty stumped at this point , if anyone can shed some knowledge I’d appreciate it .
Old Mar 10, 2019 | 08:18 AM
Try swapping the coil and plug to another cylinder. If you still get the same code for the same cylinder, then do a compression check.
