P0520, Engine Oil Pressure Switch/circuit
Hi! So I am in a bit of a pickle. I have a 2006 Dodge Charger and I had noticed I was running low on oil (its burning so i am assuming my gaskets are bad). I add more oil and not only is my PSI suddenly dropping to zero, but the check engine light came on for a P0520. Is my sensor bad?
A couple years ago my 06 magnum rt (5.7 hemi) gave me an oil pressure failure warning. Cel as well. There was no lifter noise. After a lot of panic I determined the pressure sensor was bad. Tried to change it myself but it is so well buried I ended up taking it to the shop and installed a new sensor I got from napa auto parts. It then showed correct oil pressure but continued getting the cel. Turned out only the factory sensor works.
Save some heartburn, swap out the sensor with a mopar part and be sure you have no lifter noise. Good luck.
