Sponsored by:
Sponsored by: CARiD
tried it all
Old May 16, 2021 | 06:44 AM
Joseph Nye's Avatar
Joseph Nye
Default tried it all
Have a 2006 dodge charger with 2.7 liter automatic. car running fine; then stalled turning into a driveway. car has not been right since, won`t stay running, skipping no throttle response . lightning bolt light coming on intermittently; changed throttle body, did not fix it; took to a dodge garage and they could not find the problem;drove back home. changed cam sensor; crank sensor and computer still won`t run correctly. No check engine light . A couple of codes over the past few months p2099,p0300,p2097; nothing that should make the car not stay running. to keep running i need to keep rpms at about 1500 or higher. don`t know what else to do. need help bad. been screwed up since Nov.
Old May 21, 2021 | 02:03 PM
RedRam2002's Avatar
RedRam2002
Did you change the Throttle Position Sensor and/or check the wiring and connector for it?
Old May 21, 2021 | 05:00 PM
Joseph Nye's Avatar
Joseph Nye
yes I did replace the sensor have not traced the wire yet . I will and get back to you
Old May 31, 2021 | 06:56 AM
Joseph Nye's Avatar
Joseph Nye
yes everything looks fine
Old May 31, 2021 | 06:01 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Throw the whole car away and thank your lucky stars and whatever god(s) you pray to that it didn't burn to the ground with you in it.
