Sponsored by:
Sponsored by: CARiD
No OBD II communication error
Old Apr 10, 2024 | 05:45 PM
Crapcrap2024's Avatar
Crapcrap2024
Default No OBD II communication error
I have a 2019 charger r/t 5.7L. I'm getting no communication over the OBD II port and I have a flashing/blinking fuel light. I have replaced the in tank fuel pump which is working (the car drives normally), its creating pressure and the float gauge works properly (varying resistance with float position), yet the fuel gauge on the instrument panel reads incorrectly. Any help would be appreciated. Thanks!
Old Apr 11, 2024 | 12:03 AM
SHO Rod's Avatar
SHO Rod
Are you using a scan tool that's worked on your car before? If not, since it's a 2019 your car likely has the Secure Gateway Module (SGM) which will either require a bypass cable or a scan tool that has a current subscription to AutoAuth.
-Rod
Old Apr 11, 2024 | 01:20 AM
Crapcrap2024
Thanks for your help Rod, that may be the problem. I'll check into that.
Old Apr 20, 2024 | 11:43 PM
Crapcrap2024
Thanks Rod, yes that was it!
Old Apr 21, 2024 | 11:53 AM
SHO Rod's Avatar
SHO Rod
I'm glad to hear you figured out the issue. Thank you for following up with what you found.
-Rod
