Sponsored by:
Sponsored by: CARiD
2015 ChargerRT
Old May 2, 2024 | 05:12 PM
JWK's Avatar
JWK
Default 2015 ChargerRT
After having interior cleaned, seat memory and easy exit settings do not work. Tried resetting by the manual with no results. What am I missing?
Old May 3, 2024 | 06:00 AM
Moved to the correct section. Try disconnecting the battery for 10 mins or so.
Old May 3, 2024 | 09:04 AM
JWK's Avatar
JWK
Default Seat settings
will this disturb other memory settings in my car?
Old May 3, 2024 | 10:05 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Don't disconnect the battery lol. You moved the seat too far. Need to actually READ your owner's manual LMAO:
"The Easy Entry/Easy Exit feature is disabled when the
driver’s seat position is less than 0.9 in (22.7 mm)
forward of the rear stop. At this position, there is no
benefit to the driver by moving the seat for Easy Exit
or Easy Entry."
Cycle the seat all the way forward, then back about halfway. Should start working again after that.
