Sponsored by:
Sponsored by: CARiD
High beam adjustment
Old Jan 23, 2026 | 03:57 AM
Didgeridoo's Avatar
Didgeridoo
Default High beam adjustment
The high beams in my 2021 Charger barely have any effect. I switched out the bulbs to HIDs, and adjusting the beam down helps the high beams project on the road better (obviously), but makes it so the low beams don't project far enough.
But when properly adjusted, it's like the high beams are pointed at the sky and you literally cannot even tell they are on.
Is there a way to adjust the lamp assembly so the high beams will point lower? I'm thinking I don't need brighter lights, because it won't matter if they're not pointed the right way. Or should I just look for a whole aftermarket lamp assembly?
