Sponsored by:
Sponsored by: CARiD
Exhaust system Question
Old Apr 6, 2006 | 01:50 PM
MidnightCharge's Avatar
MidnightCharge
Default RE: Exhaust system Question
ORIGINAL: IXLR8
The way I understand it is:
Charger 5.7 Hemi = 340 hp
Charger R/T any configuration = 350 hp
Charger Daytona has R/T + Flashy graphics = 350 hp
As long as you have the R/T package you already are gaining 10 hp from a free'r flowing exhaust.
All Chargers with the Hemi are R/T but you can get a R/T with the optional Road/Track Performance Group which adds these little goodies along with the extra hp
18" x 7.5" Aluminum Wheels w/Black Painted Accents
Air Conditioning with Dual Zone Auto Temp Control
Automatic Headlamps
Heated Front Seats
High-Speed Engine Controller
Load Leveling and Height Control
P235/55R18 BSW All Season Performance Tires
Perf. Seats w/Preferred Suede & Accent Stitching
Performance Steering
Performance Suspension
Power Adjustable Pedals
Power Front Seats
Power Front Windows w/One-Touch Up & Down Feature
Old Apr 6, 2006 | 02:11 PM
IXLR8's Avatar
IXLR8
Ooops... My mistake, I thought R/T was Road and Track package, but after referencing further information, I see you are correct.
Now, back to my original question. If you already have the ROAD & TRACK package, how much additional performance can you expect with an aftermarket exhaust, when you already have a free flowing factory exhaust?
The only dyno sheets I have seen show 3500 rpm up. They fail to show torque loss at lower rpm because that is not in their best interest. I may be wrong, but I have not seen evidence to support an across the board performance increases, from idle to redline.
If you did not have the ROAD & TRACK package, the aftermarket exhaust system would be a no brainer.
Old Apr 10, 2006 | 07:45 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I just put Corsa on mine... sounds good w/no drone.
If you want sound you can go with many... Flowmaster, Magflow... Home grown. Be perpared for the dreaded 2-2.5K Drone.
Here's what I've done so far:
Deleted reses and installing Blastin Bob's 11db tail pipes. Drone...
Installed Dynatech LT headers. More Drone...
Deleted stock suitcase mufflers and installed DynoMax Ultra Flow X muffler. Less Drone, but still Drone.
Deleted from the end of the mid pipes back, installed Corsa CatBack. No Drone. Zoomers will probably give the same end result as Corsa.
Both Corsa or Zoomers are going to co$t. Take your time and look for a group buy if your going with either of these.
