Sponsored by:
Sponsored by: CARiD
seatbelt noise
Old Jul 29, 2006 | 03:16 AM
topbanna3767's Avatar
topbanna3767
Default seatbelt noise
hi there i remember reading a post on how to terminate the noise on the door chime for the seatbelt anyone remember the sequence ?
Old Jul 29, 2006 | 12:34 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: seatbelt noise
There was a thread (sounded like "Tips-n-Tricks") that had this information, it musta got lost in the shuffle.
The beltminder feature may be disabled or enabled by the following steps:
1. Buckle the driver side front seat belt.
2. Turn the ignition switch on and wait for the seatbelt indicator reminder function to finish (about six seconds).
3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
4. Turn the ignition switch to any position except on or Start to toggle the beltminder feature from its current setting (from active to inactive or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been completed.
You must unbuckle and buckle quickly.
Old Jul 29, 2006 | 02:56 PM
chargin69's Avatar
chargin69
It is also in the owners manual.
Old Jul 29, 2006 | 04:20 PM
topbanna3767
great thanks for the help the chimeing noise is gone thanks yes it is in the manuel as well didnt see it thanks
Old Jul 29, 2006 | 07:10 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
You RTFMed? [sm=smiley4.gif]
For real... that's great! I haven't sat still to read the manual, I've only done selective reading from it. Now I must make time to read it because there's probably more gems in there.
Old Mar 13, 2007 | 06:50 PM
scarface36's Avatar
scarface36
wuzzup, new to the forum,i bought my 06 rt on sat. I think i gotta try it it again ending with it on.U gotta do this everytime u get in the car?
Old Mar 13, 2007 | 08:09 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the Charger family and the forum!
You got to listen to the chime every time unless you step through turning it off.
Nope, this is a switch and the steps to turn the chime minder on or off. If you go through the steps it turns it off, if you go through the stpes again it turns it on.
Hope that helps.
