Sponsored by:
Sponsored by: CARiD
fog light install
Old Aug 15, 2006 | 11:58 AM
BigBananna3796of4000's Avatar
Default fog light install
I made the msitake of ordering High and Low beam Xenon Lights on Ebay for 9.99. Well 2 of the blew on me already so I ordered new ones including fog light and interior lights of http://www.autolumination.com/.
I havent looked at the fog lamps yet do they just screw out like the head lamps?
Old Aug 15, 2006 | 11:34 PM
Default RE: fog light install
Anybody on this one? I got my bulbs today.
Old Aug 16, 2006 | 01:26 AM
Daytona RT's Avatar
Daytona RT
Nanner.. first the obvious..
You of course know the bulbs must be handled in such a way as to not get your fingerprints & oil on them?? as much a bother as it is.. I use gloves when installing either the new healight bulbs or the high output foglights.
As for the foglights.. I'm guessing here.. but If they are like my last set they remove from the back with a twist. unclip from the wire harness, replace and twist back into place.
Good luck
Old Aug 16, 2006 | 01:44 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I've heard you should attack this from underneath. Take off the main underbelly plastic dirt cover/skid plate and the small one it attaches to, then the foggers are easily accessible from below. I also assume it a twist in/out.
Old Aug 20, 2006 | 05:48 PM
Midnight Blue's Avatar
Midnight Blue
Pretty much. If I remember right it was two selftapping screws and three snap fasteners per side. Since everything is plastiec, you can pull down on the bottom cover enough to get your hand on the fogs. Twist out, snap off the connector. Reverse to install. About 10 mins to do both sides once I got my car up on the ramps.
Redbeard
Old Aug 21, 2006 | 04:23 PM
Thanks your are right I had to attack it from underneath the skid plate.
