Sponsored by:
Sponsored by: CARiD
180 degree Thermostat
Old Aug 16, 2006 | 11:05 PM
IXLR8's Avatar
IXLR8
Default 180 degree Thermostat
My Daytona seems to run at around 215 degrees. It is hot here in Houston, I would like to run it a little cooler, I thought the thermostat would do the trick. Where do you get one? Does anyone have a part number? Is it easy to install? Does Dr. Z need a hairpiece?
So many questions....
Old Aug 16, 2006 | 11:44 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: 180 degree Thermostat
Mine also ran hot; the OEM T-Stat is 203 degrees. I ran the NAPA 190 for a while and now I'm running the Stant 180, with no issues. Some will argue that the T-stat shouldn't vary from the stock 203 degree T-stat. It's a very debatable topic and you will see many threads discussing this.
If you decide to mod you’re after a 2.5 inch wide (63mm) T-stat.
NAPA
180 degree 191 THM
190 degree 190 THM
Stant
160 13076 - 160, 13476 - 160
170 13947 - 170, 14127 - 170, 14177 - 170
14687 - 170 very long looking
180 13078 - 180, 13948 - 180, 13478 - 180, 14128 - 180, 14168 - 180, 14178 - 180, 14248 - 180, 45478 - 180
190 14429 - 190 very short looking aka Napa 381-190
195 13079 - 195, 13079 - 195, 13479 - 195, 14039 - 195, 14269 - 195, 45479 - 195
205 14252 - 205
Motorad
160 7206-160 (Eskimo T-stat J/K)
180 7206-180
195 7206-195
Old Aug 17, 2006 | 12:28 AM
IXLR8's Avatar
IXLR8
Wow!
Thanks for the great info Mango!
