Sponsored by:
Sponsored by: CARiD
Directional Fuse/Relay???
Old Sep 5, 2006 | 01:05 AM
06ChargerSXT's Avatar
06ChargerSXT
Default Directional Fuse/Relay???
I just put LED light bulbs in for the
brake lights/turning flash
the problem is that the 4 ways flasher work normal
but the turn signal flasher is very fast. if you turn
the IGN off then on it will flash normal for about 6 flashes
then goes into fast mode any way to fix this.
Old Sep 5, 2006 | 11:37 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Directional Fuse/Relay???
You need 2 3-ohm equalizers, one on each side, mounted either front or rear.
It requires a load resistor to avoid the fast flash rate that happens when the current draw is too low. (LED's draw a lot less current than stock bulbs.)
