SRT rocker arm covers
When I remove my engine shroud cover I notice a bunch of wires coming our of the valve covers.
Does the SRT have some additional engine dress valve covers that hide them if I want to run w/ o the heat trapping shroud?
Where do I find them?
So you have a "rats nest" of wires?
It doesn't look like this does it?
[IMG]local://upfiles/33009/0B32E432CE3143189200AE04C3E306E3.jpg[/IMG]
<edit> If you have a "rats nest" you can get rid of it by re-wiring with "shorty wires"
I initially thought you had wires running up-n-over the engine OMG what a relief that isn't the case.
I havent' see anything aftermarket that fits this nitch. Not sure if the SRT8 would fit but I don't forsee a reason it wouldn't.
I wouldn't mind something like the SRT-8s valve cover shourds but only if their easy to get on and off. I don't want a hassel if I need to get up in there and work <= just my 2 cents
<edit> We can ask out very own 65Standard over in the Magnum Section, he may be the only one with a R/T and the SRT-8 covers. You will need four mounting studs. The side where you fill the oil needs to be trimmed a little. The existing top hat studs can be replaced w/normal bolts since they will not be used.
Also, you’ll need an anvil to pound out that SRT 8 6.1 raised letters
heck their probably plastic so forget that.
