Sponsored by:
Sponsored by: CARiD
radio installation problem
Old Nov 5, 2006 | 06:40 PM
ITZOOHBOY's Avatar
ITZOOHBOY
Default radio installation problem
when i wire my new radio to the wiring harness theres no power when i turn the car on.
Old Nov 5, 2006 | 07:18 PM
RT 2 NV's Avatar
RT 2 NV
Default RE: radio installation problem
you should wire the harness to the radio and then it should plug into the factory harness. i thought it should be color for color. been awhile for me thou. good luck.
Old Nov 9, 2006 | 01:23 AM
06ChargerSXT's Avatar
06ChargerSXT
Is it an aftermarket radio?
If so they should have a wire harness for it
Match the colors to it. Also check the in line
Fuse on the new radio if it has one
And the fuse in the cars fuse box. Make
Sure there not blown
Old Nov 9, 2006 | 02:03 AM
ITZOOHBOY's Avatar
ITZOOHBOY
YEAH I BOUGHT THE AFTERMARKET HARNESS EVERYTHINGS GOOD BUT IT GETS NO POWER. I EVEN TRIED IT ON MY CIVIC AND IT WORKED FINE
Old Nov 9, 2006 | 02:57 AM
06ChargerSXT
Did you check the fuse?
If that’s all good I would try to
Power it direct run a power and a
Negative wire fro the battery
