Sponsored by:
Sponsored by: CARiD
TSB
Old Nov 12, 2006 | 11:25 PM
BigBananna3796of4000's Avatar
Default TSB
Rolled my car out of the garage to clean her and I discovered 2 big spots of tranny fluid. Is there a TSB for the transmission on the 5.7?
I noticed the car shifting funny last week when I stomped on her. It was sliding into gear and not shifting hard.
ANy ideas?
Old Nov 12, 2006 | 11:42 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: TSB
There seems to be a rash of Magnum/300/Chargers w/the 5.7 engine having this issue. Apparently it's a O-ring on the 13 pin adaptor on the side of the tranny.
I looked up and didn't find any TSBs on this issue. Here is where I did the lookup Here is where I did the lookup.
Sorry, but you should take it to a dealership and they should fix it without any hassle.
Old Nov 13, 2006 | 12:05 AM
Default RE: TSB
Thanks for the info.
She goes in tomorrow am.
I am also going to have them fix the trunck rubbing.
Apparently Chrysler is saying the spoiler in causing too much dwn force. I think it is just the bushings.
Old Nov 13, 2006 | 02:52 PM
stewtina's Avatar
stewtina
Default RE: TSB
We had the same problem Mango is right took it to dealer and within the hour it was done. no problems since. I'm still upset i cant check fluid though. Maybe i will change it to amsoil for the peace of mind. We have the rubbing also maybe we can get this minor problem fixed.
Old Nov 13, 2006 | 03:05 PM
RT 2 NV's Avatar
RT 2 NV
Default RE: TSB
how many miles do you have on your car. thanks
Old Nov 13, 2006 | 03:47 PM
baldyloxs's Avatar
baldyloxs
Default RE: TSB
They say you should never need to check the tranny fluid unless it is leaking.I called about a week ago and questoned them aboit it.They told me all the auto manufactures are going that way.
Old Nov 14, 2006 | 12:31 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: TSB
I just checked the Magnum Section, there's quite a few tranny leaks over there also. DCX should put this to bed w/a TSB [&:]
Old Nov 14, 2006 | 02:23 AM
stewtina's Avatar
stewtina
Default RE: TSB
12000 miles leaked at 8500 if i remember right.
Old Nov 14, 2006 | 01:52 PM
atnyman's Avatar
atnyman
Default RE: TSB
Had my trunk lid ajudted 3 times rubbing still there. Rt And trunk does not close right now. All they do is keep adjust it off center so they lessend the rubbing but wont close right
Old Nov 14, 2006 | 03:37 PM
74scamp's Avatar
74scamp
Default RE: TSB
Have you tried turning the rubber bumper/stops around? If not, try turning them around 180 degrees so the tall side is facing outward. I used a pair of big plyers to do mine.
dave
