Sponsored by:
Sponsored by: CARiD
limited slip rear end
Old Dec 17, 2006 | 04:36 AM
topbanna3767's Avatar
topbanna3767
Default limited slip rear end
quick question would a limited slip rear end effect the esp on the car .i was thinking about putting in either limited slip or locker would either system effect the esp or abs system ?
Old Dec 17, 2006 | 07:02 AM
Zedd's Avatar
Zedd
Default RE: limited slip rear end
Both the ESP and ABS should use individual sensors for each wheel. That being the case, it shouldn't make any difference if you are driving one or both rear wheels when they break loose. Both systems should still apply braking power to whichever wheel needs it for their purposes.
Old Dec 17, 2006 | 03:37 PM
bmdmc's Avatar
bmdmc
Where does one find a limited slip diff for and CSRT8?
Old Dec 17, 2006 | 05:18 PM
baldyloxs's Avatar
baldyloxs
(when ESP is working right it seems though we have POSI ,not the case)thats why if you have the ESP mod the totally removes it .you should get a locker or you are only getting one wheel peel out of theses open rearends.
