Sponsored by:
Sponsored by: CARiD
quick question on the windows
Old Jan 27, 2007 | 12:30 AM
topbanna3767's Avatar
topbanna3767
Default quick question on the windows
i remenber i read a while ago about windows needing to be recalibrated by pulling the up switch on the door and then leaving it up for a second longer then when it goes up for .cant remember exactly anyone help out ?
Old Jan 27, 2007 | 03:56 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: quick question on the windows
So, TB3767, are you back to normal now
Here's what your after, and more...
BATTERY RECONNECTION
Note: This reconnection procedure is to be performed anytime the battery has been disconnected.
1. Connect the battery negative cable (2) to the battery
post and tighten the clamp nut.
2. Install the rear compartment floor trim panel.
CAUTION: Once the battery has been connected,
review and perform the following information as
applicable.
AUTO UP FRONT WINDOW
If the vehicle is equipped with the auto-up front window feature, once the battery is reconnected the door module
needs to be calibrated. The door module requires calibration anytime the battery or door module has been disconnected
for any length of time. To calibrate, perform the following:
1. Connect the battery cables.
2. Using the window switch, raise the window to the full UP position. Hold the switch in position for 1 second, then
drive the window all the way down to the bottom.
ELECTRONIC STABILITY PROGRAM (ESP)
If the vehicle is equipped with ESP, once the battery is reconnected, the Steering Angle Sensor (SAS) needs to be
calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for
1. Start the engine.
2. Center the steering wheel.
3. Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the
wheel all the way to the right until the opposite internal stop in the steering gear is met.
4. Center the steering wheel.
5. Stop the engine.
Old Jan 27, 2007 | 06:08 PM
topbanna3767
great to hear from you .hows it going ? yes and the universe is again all better ;0 )
Old Jan 27, 2007 | 08:16 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I've had the work blues. Auditors are in town auditing us and we doingdisaster recovery testing.I was up inBoulderdoing network recovery tests from 8amThursday to 8am Friday. It's a grueling 24 hour thing. Next Wednesday is round 2only it's in the area, no travel involved.
Drove over to Fort Worth today and dynoed with a couple other Charger folks. You'll see the post in the V8 section.
