Rear hub removal, need help
Been trying to rebuild the breaks on a 56 custom royal, problem: How do you remove the keyway from the rear axel assy to remove the hub and drum? The shop manual only says to remove the keyway but does not explain how. I have tried a gear puller but the hub did not budge. I need to get the keyway out.
Any help would be greatly appreciated.
Thanks
Thanks
