1941 Dodge Luxury Liner convertible top motor wiring and switch
Old Jan 21, 2017 | 11:16 PM
Jon Mikkelsen's Avatar
Jon Mikkelsen
Default 1941 Dodge Luxury Liner convertible top motor wiring and switch
Not sure if this should go in the more modern tech forum or here with the old stuff, so here goes:
My 1941 Dodge D19 Luxury liner convertible has mechanical top raising/lower motors. I just got the motors running again and need a source for wiring information.
The motors spin clockwise nice a smooth, but no matter how I hook up the power source, I can't seem to make them go backwards. There are three color banded wires going into each motor. Red, Black, and Green. Should be positive red, negative black, and ground green, right? How would a guy hook these up to make them spin backwards too? The has to go both up and down after all.
Any information you can offer for leads to experts or even actually wiring information would be great to read.
Thank you,
Jon
Old Jan 21, 2017 | 11:18 PM
Jon Mikkelsen
Default hook ups that work
Should have included:
When a battery positive is hooked to red, and a battery negative is hooked to black, the motors spin clockwise. No other hook ups spin, not even reversed positive to ground.
Thanks,
Jon
Old Jan 22, 2017 | 12:57 PM
Jon Mikkelsen
I just double checked the hook up results and the motor still spins the same direction when I hook the positive to black and negative to red. Hook ups involving the green wire don't seem to do anything.
Old Feb 25, 2017 | 01:54 PM
Jon Mikkelsen
Aaah, learning that this was originally a 6v positive ground car I tried the hookups again. Red to ground was scary to accept. Hooked up positive 12v to the green wire and it spins one way. Hooking 12v positive to black spins it the other way. Yeah!
Now I am looking for a convertible top switch and a 12v to 6v high amperage drop down converter so the motors don't spin at a hundred miles an hour and damage the top.
Thanks for your input and for the input of the folks at the Circuits forum.
Jon
Old Mar 6, 2017 | 10:41 PM
Jon Mikkelsen
Default What is this wiring piece between the starter and the cabin wiring
Hi folks,
I am now looking for the best point to take positive voltage for use in the 1941 Dodge convertible top now running a 12v positive ground system.
Positive wiring comes from the battery, to the starter, then to this little round thing showing in the center of the attached picture with the red and other wires coming in & out of it. Wires pull off of the inlet post on the left, another post on the right, and even one of the little posts in between.
What is this thing? The round plastic piece that these wires all hook up to? It is made by Standard as says the recognizable "S" logo on top of it. What does it do? What happens when I pull power before it or after it?
Where should I draw power from to route to a breaker and the wiring for the power top?
Thank you!
Jon
Attached Thumbnails 1941 Dodge Luxury Liner convertible top motor wiring and switch-1941-dodge-wiring-thing.jpg
Old Mar 30, 2017 | 02:03 AM
marty mopar's Avatar
marty mopar
www.aaca.org for help on the older Mopars
